Alt Limit Issue https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5452 |
Page 1 of 1 |
Author: | jasc [ Tue 01. Nov 2022 8:16:12 ] |
Post subject: | Alt Limit Issue |
Hi I tried to test geofence with hard deck limit - both on the same channel, configurator showed both in state On(1) when activated. When activated the heli just climbed slowly. I switched off after like 3m. Is this normal or is there smth wrong. Geolink is on the boom (Logo550) I just did a hover test, to ensure functionality so I didn't try any further |
Author: | ZeXx86 [ Tue 01. Nov 2022 8:31:21 ] |
Post subject: | Re: Alt Limit Issue |
Hello, after engaging it should start to climb for 1.5 seconds. Then from this altitude it will engage whenever model will move under this altitude where it was engaged. Maybe this page can help you: http://manual.spirit-system.com/index.p ... tude_Limit |
Author: | jasc [ Tue 01. Nov 2022 12:21:26 ] |
ZeXx86 wrote: Hello, after engaging it should start to climb for 1.5 seconds. Then from this altitude it will engage whenever model will move under this altitude where it was engaged. Maybe this page can help you: http://manual.spirit-system.com/index.p ... tude_Limit whoever can read... PLease put these infos under "Usage"... - If you go through it to set it up, you read the instructions, not the introduction |
Author: | ZeXx86 [ Tue 01. Nov 2022 12:47:22 ] |
I dont understand what is wrong when the behavior is described in "How it works" while how to use it is in "Usage". Can you let me know why it is wrong now? |
Author: | jasc [ Tue 01. Nov 2022 14:04:30 ] |
ZeXx86 wrote: I dont understand what is wrong when the behavior is described in "How it works" while how to use it is in "Usage". Can you let me know why it is wrong now? no, all good... When I programmed everything an tried to memorize how it works, I only paid attention to 1.2-1.4 |
