It is currently Sat 23. Nov 2024 3:52:55
[ 3 posts ] |
UpAndDown
Posted: Thu 08. Dec 2022 21:01:41 |
Hi there,
I am happy about the new Spirit System 2, though there is a question I have about the normal flight mode, i.e. no stabilization and no recovery activated. I am flying a helicopter with flybar, and for that reason I bought the Spirit System, because it supports it, another reason is I want to have a rescue function.
So, rescue and stabilization a working fine, but in the normal flight mode there is also some stabilization applied.
What I mean is: if the helicopter mechanically nicks or rolls (without touching the control sticks), the swashplate moves to the opposite direction of that movement for a few seconds while it gradually returns to its normal position (parallel to the landing gear).
What I expected is that the swashplate would not move at all as long as there is no stick input on the remote, regardless of whatever the helicopter does.
I see that this small stabilization is required if the model is flybarless, but here we do have a flybar, and I have ticked the respective option in the menu (and saved that setting). I have also checked in the diagnosis tab that indeed rescue and stabilizatition are both disabled.
So, long text short: can this stabilization effect in normal flight mode be disabled at all for the flybar setting, or at least be reduced by any setting?
Thank you for your answer
Posted: Fri 09. Dec 2022 9:31:48 |
it can be reduced by changing Geometry 6 degrees to the lowest value. However it will be always enabled to some extent to make the flight more stable and precise.
Posted: Fri 09. Dec 2022 9:50:30 |
Joined: Sun 09. Jun 2013 13:14:17 Posts: 997 Location: Plzeň
Wouldn't it help reduce the cyclical gain?
_________________ Spirit System (Spirit W1, RS & GTR & all the others) Spirit Wave & JETI DS 12 http://www.habada.cz
[ 3 posts ] |
Users browsing this forum: Bing [Bot] and 60 guests |
