It is currently Fri 22. Nov 2024 23:45:38
Post new topic Reply to topic  [ 10 posts ]
PostPosted: Wed 26. Oct 2022 10:48:21
Hi all, is the Spirit capable of electronic phasing on a multi blade scale helicopter?
PostPosted: Wed 26. Oct 2022 13:16:35
yes, see our manual:
https://manual.spirit-system.com/index. ... T_SETTINGS
PostPosted: Thu 27. Oct 2022 10:48:53
Thank you! I knew it could do it I just couldn't find it in the software. It's called cyclic phase :)
PostPosted: Mon 05. Dec 2022 4:38:03
Is the phasing accessible for a two blades model to retard swash phasing a bit for more axial rolls? It seems to be greyed out on my screen.
Ben Minor
PostPosted: Mon 05. Dec 2022 8:25:08
Hi Ben
is it possible that you are NOT in bank 0 when trying to change the value?
cheers
Michael
PostPosted: Tue 06. Dec 2022 3:57:13
Edited. Problem solved. I wasn't thinking correctly about the phasing output with an ele input. All is well. What I had written would only serve to confuse.
PostPosted: Tue 06. Dec 2022 7:51:10
Dr.Ben wrote:
Michael,
Thank you for your reply. I found it to be active, but now I am quite confused. ......
Hi Ben, i am just a user here as you are - i cannot explain ;) so it's a question for @ Tomas !
cheers
Michael
PostPosted: Tue 06. Dec 2022 8:16:26
Thanks Michael. I emailed Tomas and asked for his comment here and on a post I had made about cyclic tuning.
Ben Minor
PostPosted: Tue 06. Dec 2022 8:38:04
cyclic phasing should work identically on all models and FBL units.
It is working in the way where swashplate movements are rotated in one or another way by degrees you will enter.
Both axes are rotated always in the same direction, otherwise it does not make sense.
If you are getting incorrect behavior then it mean that your basic setup is not correct unfortunately.
You can check it easily in this way:
1) Enable normal flight mode
2) Move with collective pitch up and down
3) Check Diagnostic tab if the Pitch bar is moving up and down in the same direction as your stick.
4) Check that you have correct Swashplate Type
PostPosted: Wed 07. Dec 2022 5:50:56
Thank you Tomas. My issue is resolved and all is well.
Ben Minor
Users browsing this forum: Amatrix, Bing [Bot] and 47 guests
cron
