the rudder gain is only the prortional part of the rudder controll-loop - the rudder common gain is only an factor of the porportional rudder gain - In some configurations the value with the multipier x1 is to less to get an proper behavior so you must the multiplier to 1,5 for example - afterwards you have to correct the rest of the control-loop (with I-Gain and D-Gain) - In the spirit you have here to set the
rudder delay (among other things, servo-dependent) and the rest of the loop is the
Advanced/Piro Consistency -
Very well described how to set rudder and cyclic see here:
http://manual.spirit-system.com/index.php?title=Tuning_GuideBest Regards
Matthias
