At first: Flying the units is perfect.My setup: Spirit GT + Geolink V2 on a RAW580
Spirit GT + Geolink V2 on a TREX 600E PRO
The vibrations are between 8 and 20
BEC test succesfull
But when i like to use the supported features i run in problems.
After the update is the same than before the update at my units, nothing gets better.
1.When i like to look in the Geolink log´s the first log is most possible to look.
The next flights are set with timestamp 0 and not choosable.
A fault that the geolink data are corrupted is shown in the log viewer.
2. When i take the advanced fligtviewer try to look in the realtime log there are crazy high values which "kills" the logs.
For example: speed 6000km/h, Vibration 2400
it is independant which or how much values i set and how often per second i set.
I´ve done factory reset, reprogramming. Update every unit to 3.4.2 and 1.3.1
nothing helps
But, once more, flying is perfekt
File comment: Look at the timecode by the log selection
