It is currently Sat 23. Nov 2024 4:06:12
Page 1 of 1
[ 3 posts ] |
Author |
Message |
Bladecrasher
Posted: Thu 22. Sep 2022 2:43:59 |
Every time I need to get my DX9 setup with a new model - I have to F..K around with the reversing on the TX and Spirit before the swash is moving correctly.
This is such a BS problem, there must be a step-by-step "how-to" explanation of getting this resolved. Does anyone have a link to something helpful or an explanation of the process of elimination.
The manual seems useless for this.
Thank you,
Top |
Posted: Thu 22. Sep 2022 8:56:36 |
Site Admin |
there are only two steps that you have to do in regards to reversing.
1. Reverse radio channels according Diagnostic tab/Setup wizard and from then never touch these reverses. 2. Reverse servos in the Servos tab/Setup wizard to achieve correct movements. It is enough to move with pitch stick up and down and reverse all servos that are moving in a wrong direction.
Then you are done.
If you are using a digital channel transmission protocol such as Spektrum DSM2/X or SRXL2 (no PWM or PPM) then point 1 will be correct out of the box. So then no reversing in your radio is needed at all.
In other words it is enough to proceed according Setup Wizard.
Top |
Bladecrasher
Posted: Fri 23. Sep 2022 13:30:15 |
Thank you. Re-doing the Wizard made this easy.
Top |
Page 1 of 1
[ 3 posts ] |
Who is online |
Users browsing this forum: No registered users and 60 guests |
