Spirit System
Min Altitude settings for RC changed?
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5376
Author:  AlexAusTelfs [ Sat 03. Sep 2022 9:36:36 ]
Post subject:  Min Altitude settings for RC changed?
Hi folks,
I updated to latent FW and found (during pre-flight test) that switch for min altitude changed function. If I would have started heli min Altitude would not possible to deactivate and heli would be lost! It worked with old firmware.
After changing switch range (Jeti DS12) switch now works properly.
For EVERYBODY: By any means check proper function of this function after update or you may loose your heli.
Alex
Author:  luke457 [ Sat 03. Sep 2022 13:32:53 ]
Post subject:  Re: Min Altitude settings for RC changed?!
As is does warn you in changelog
Author:  ZeXx86 [ Mon 05. Sep 2022 6:05:33 ]
there is a change in 3.4.1 already, so that when you engage Altitude Limit it will go up for 1.5 second from a moment it was engaged - considerig that you have the same settings. But the worst thing it could do is that Altitude Limit will change from what was set in the software.
You still have a possibility to disengage the function at any moment. So the model will not continue in this function as soon as it is deactivated with your switch.
All features are done so you can turn it off at any moment, so it should react in notime.
I can recommend to always read change log in each update, because sometimes there could be important things to check or change. In this way you can avoid unexpected behavior.
We are sorry for the troubles in any case.
http://www.phpbb.com/
