Sprit GT and Geolink V2 fault´s in log https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5369 |
Page 1 of 2 |
Author: | notround [ Mon 29. Aug 2022 13:33:11 ] | |||
Post subject: | Sprit GT and Geolink V2 fault´s in log | |||
At first: Flying the units is perfect. My setup: Spirit GT + Geolink V2 on a RAW580 Spirit GT + Geolink V2 on a TREX 600E PRO The vibrations are between 8 and 20 BEC test succesfull But when i like to use the supported features i run in problems. After the update is the same than before the update at my units, nothing gets better. 1.When i like to look in the Geolink log´s the first log is most possible to look. The next flights are set with timestamp 0 and not choosable. A fault that the geolink data are corrupted is shown in the log viewer. 2. When i take the advanced fligtviewer try to look in the realtime log there are crazy high values which "kills" the logs. For example: speed 6000km/h, Vibration 2400 it is independant which or how much values i set and how often per second i set. I´ve done factory reset, reprogramming. Update every unit to 3.4.2 and 1.3.1 nothing helps But, once more, flying is perfekt Attachment:
File comment: Look at the timecode by the log selection
Author: | ZeXx86 [ Tue 30. Aug 2022 15:53:30 ] |
Post subject: | Re: Sprit GT and Geolink V2 fault´s in log |
Hello, thank you very much for the question and sorry for the troubles. We will check your settings and logs. It seems there are two different problems, because both logging are completely separated from each other. Unfortunately I fear it will require adjustments in the software. |
Author: | notround [ Wed 31. Aug 2022 14:28:27 ] |
Thanks. If you need more data, you can ask. |
Author: | Herve [ Sun 04. Sep 2022 14:25:13 ] |
Hello, Do your troubles look like these ? Thank you. Hervé |
Author: | Mattes61 [ Sun 04. Sep 2022 15:17:01 ] |
Hello Herve, I think we have all the same problems (notround, mattes61 and you) Attachment: Tomas said that there will be an update to fix the problem in some days Look in my thread also: https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5349&start=10 Regards Matthias |
Author: | Herve [ Sun 04. Sep 2022 15:42:09 ] |
Hello Matthias, I thank you for your response. Yes, I saw your thread and Tomas answer, but I wanted to be sure that it was the same issue. With regards. herve |
Author: | notround [ Sun 04. Sep 2022 17:55:26 ] |
Hi, yes the same issues + Geolink V2 corrupted logs |
Author: | ZeXx86 [ Sun 25. Sep 2022 12:56:36 ] |
Hello, if your model is producing too much electrostatic discharges the GeoLink itself could restart, because it is sending too high voltage there. This is indicated by Green led light after landing. If this will happen GeoLink log might not show for the present flight immediately. But it is fixed automatically when next log is added. You can check if after more flights the missing log will show. Although high voltage spikes are relatively dangerous for whole electronics on the model we will try to make it seemless even if logging is interrupted in next updates. For now it is enough to do more flights and the logs are fixed automatically. |
Author: | ZeXx86 [ Sun 25. Sep 2022 13:01:08 ] |
Can you share how GeoLink is mounted on your model? You can start with the minimum value for the Vertical Correction Gain. This should help. |
