Problems with Windows Application 3.4.1 https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5358 |
Page 1 of 3 |
Author: | malelo1960 [ Thu 25. Aug 2022 10:36:13 ] |
Post subject: | Problems with Windows Application 3.4.1 |
Hello together, i have a nervy problem with the windows application Spirit 3.4.1: If i go to settings of the geolink module another window open. But the setting parameters in the down positions are not reachable for me, because the window is out of range. My graphic settings on my notebook are 1366 x 768 which is very common 15" screens and its not possible to make them higher. The window for the setting should be scrollable or able to maximize. I think that the programmer used another resolution and fixed the window. It is not possible to move the window more high to get access, only down works. So, what can i do. I tried yesterday for hours with my windows 10 settings without any solution. Thanks a lot for your help. Greetings, Mario |
Author: | ZeXx86 [ Thu 25. Aug 2022 10:52:37 ] |
Post subject: | Re: Problems with Windows Application 3.4.1 |
Hello, in some systems fonts are enlarged very much in the system settings. It should be enough to decrease system font size as temporaral solution. Could you maybe take a screenshot so I can see how it looks on your notebook? Our app is optimized even for smaller screens. So I guess there is some unusual font settings. |
Author: | malelo1960 [ Thu 25. Aug 2022 11:05:06 ] |
Dear Sirs, as an attachment you get a screenshot. My windows scaling is on the lowest 100%. Less is not possible. Attachment: Thanks for another solution.... |
Author: | urgno [ Fri 26. Aug 2022 8:54:03 ] |
have you tried to resize the window from top to smaller size ? then you should be able to move it up |
Author: | proctormw [ Sat 03. Sep 2022 15:28:35 ] |
Had the seem problem. Temporary fix is go to display and change from landscape to portrait. It’s a little tricky moving the mouse but you can get to the settings |
Author: | amal2029 [ Sat 03. Dec 2022 4:42:25 ] |
Mr.Tomas, I really need your help on this matter. I could not access the features of Geolink in my notebook as the Geolink selection window's bottom potion is not visible. Attachment: Spirit SW: V3.4.3 Notebook OS: Win 7 Pro 64Bit Screen resolution: 1440 X 900 (Maximum available) Spirit main window appear normal as before. Attachment: Attachment: This is my Notebook that I reserved for RC Heli use and which I use on the field. I really need you help to make it usable. Thank you and regards, Amal |
Author: | ZeXx86 [ Sat 03. Dec 2022 9:08:32 ] |
Hello, you can change window size by right clicking at the window title and selecting option to maximize for example. This will make it to fit well. The window size will be saved for next time with the latest version. |
Author: | amal2029 [ Sat 03. Dec 2022 12:48:34 ] |
Mr.Tomos, I am using the maximum available. Attachment: Is there a way you can adjust some settings of Spirit program to fit into 1440 X 900 resolution? Regards, Amal |
Author: | amal2029 [ Mon 05. Dec 2022 3:49:45 ] |
Mr.Tomas, Is this the method you advised: right click on Spirit shortcut icon on the windows and go to properties, Shortcut, Run and change to minimize? Attachment: I am sorry, it does not work that way. Attachment: Regards, Amal |
Page 1 of 3 | All times are UTC + 1 hour |
