It is currently Fri 22. Nov 2024 23:56:00
PostPosted: Tue 23. Aug 2022 14:26:57
Just wondering if I may have missed something simple (again lol) with getting the telemetry going from a Kosmik 200 through a RS FBL to a Jeti DS12.
I believe I'm following all the correct steps but just get a "0" value for any ESC telemetry display.
I'm using the Spirit Telme method (http://manual.spirit-system.com/index.p ... _Telemetry) and the telemetry was working ok before with a Mikado Telme cable and my old VBCt radio.
Kosmik has the latest firmware - 4.17
Cable is plugged into the Kosmik centre 5 pin port and Spirit Sat1 port
Confident that I am setting up / displaying the tele correctly in the Jeti (as I have a couple of HW escs working fine)
One thing though is that every time I turn the Jeti Radio OFF - When I go back into the Spirit Tele Settings (through the Jeti) the Telemetry option is back to Disabled?
Thanks again for any assistance!
PostPosted: Wed 24. Aug 2022 13:01:33
Further to my above problem - I thought Id try another Kosmik 200 I had spare.
The original Kosmik I was trying was the earlier version (with the flat top) and the other one was the newer "heatsink top" version.
Happy to report (kind of) that the Telemetry worked fine on the newer Kosmik (heatsink) version.
Both ESCs were running the latest firmware (4.17) so not sure why one works but the other doesn't (and both were fine with the VBCt Telme telemetry before I switched back to Spirit / Jeti).
Anyway will just swap the ESCs and leave the older Kosmik to another day!!
PostPosted: Fri 18. Nov 2022 13:40:30
Just another issue with the Kontronik Kool telemetry running through a Spirit RS and Jeti DS12.
I am getting really excessive amp draw tele values (Kraken 700 / 12S lipos).
Typically the value is reading over 600 amps!
The other tele values sem to all be reasonable (eg lipo volts, rpm etc).
Just wondering if anyone had come across these excessive amp values - especially from a Kontronik esc.
Thanks for any advice
Users browsing this forum: No registered users and 46 guests
