It is currently Sat 23. Nov 2024 11:51:44
[ 3 posts ] |
Omegaman
Posted: Thu 14. Jul 2022 18:35:13 |
Hello, I upgraded my align 470 to the latest firmware and went for two flights on the 12/07/2022. All seemed well. Really impressed with the new rth function although at 30m the 470 looks like a dot in the sky. When I came to look at the geolink flight logs the first one was as normal, one continuous 4 minute log. With the second flight the log was split into 5 short logs which I've never seen that before. I checked the connections on the spirit pro and geolink which appeared okay (I disconnected and reconnected them to be sure). I flew two flights today and all seem well with no problems in flight except when I checked the flight logs both were split up into many segments. My other heli has been upgraded with the latest firmware and the geolink flight logs are continuous. Is there anything I can try to sort this problem out? Many thanks
Posted: Thu 14. Jul 2022 18:56:26 |
GeoLink flight logs are recorded when vibration level is over 5%. You can see the level in telemetry. So when model will stop the motor, it will stop the log.
Can you check if vibration level drops above this percentage when flying?
Omegaman
Posted: Fri 15. Jul 2022 11:28:46 |
[ 3 posts ] |
Users browsing this forum: No registered users and 57 guests |
