Spirit System
Whats new with GeoLink V2
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5244
Page 1 of 2
Author:  Dr.Fleming [ Wed 15. Jun 2022 10:57:01 ]
Post subject:  Whats new with GeoLink V2
Whats new with GeoLink V2 !? :ugeek:
Author:  urgno [ Wed 15. Jun 2022 14:14:13 ]
Post subject:  Re: Whats new with GeoLink V2
here you will find the features and pictures ;)
https://store.spirit-system.com/en/acce ... olink.html
Author:  Dr.Fleming [ Thu 16. Jun 2022 8:18:20 ]
But I like to know how the Laser works, I supose that is facing down, also installing on a boom
will be a problem ! The point is, if I must order the GeoLink Holder or not.
Author:  sacha [ Thu 16. Jun 2022 13:39:14 ]
I think that we have to drill a little hole into the geolink plattform.
So the laser has a plain sight downwards.
Sacha
Author:  urgno [ Thu 16. Jun 2022 13:52:14 ]
Author:  Dr.Fleming [ Thu 16. Jun 2022 14:46:43 ]
Yep, but if you installed on the boom ! :roll: ( It's wider !)
Sacha
Author:  ZeXx86 [ Thu 16. Jun 2022 14:53:36 ]
if you use our GeoLink Holder then it will work just well with no modification. However Laser usage is optional, so if it is covered in some model it is not a problem.
What is new?
Basically everything. All components are new and is based on the latest technology. It has much more processing power and available memory. So it can do much more things.
Now it is only dependent on firmware, because nearly anything is possible with this module. We plan to add many interesting features with each update, because it is simply possible.
Author:  Dr.Fleming [ Thu 16. Jun 2022 15:29:58 ]
Ok will see, but I like to use the Laser, specially for Autolanding as a Failsafe will be great.
I order few Geo's on Backorder, when you expect ready for sent? :mrgreen:
I'm not sure to order one more Geo Link Holder :|
What is new?
Author:  sacha [ Thu 16. Jun 2022 15:38:42 ]
I also ordered a few units. Can't wait to receive it ;-)
Author:  nichtdiemama [ Sat 18. Jun 2022 16:11:39 ]
If the new geolink is so powerful how would it be with an failsafe autorotation. If failsafe aktive then negative pitch and shortly before the ground positive.
http://www.phpbb.com/
