It is currently Sat 23. Nov 2024 1:46:04
PostPosted: Tue 21. Jun 2022 15:21:03
Am newbee, i need help on spektrum ix12 and spirit pro set up on channel servo. Am done calibrating geo link and gyro is working and bind with 4651t but servo not moving with tx sticks
PostPosted: Tue 21. Jun 2022 20:02:45
you need to set Spektrum SRXL2 receiver type in the Spirit Settings and also to use Spektrum SRXL2 Adapter connected according this guide:
http://manual.spirit-system.com/index.p ... 2C_SPM9747
PostPosted: Fri 24. Jun 2022 3:59:03
How to we start or arm the motor? Or just touch a switch assigned to throttle to turn on the motor?
PostPosted: Sat 25. Jun 2022 11:40:18
Hello Kamote,
maybe this links will help you:
http://manual.spirit-system.com/index.php?title=Main_Page
http://manual.spirit-system.com/index.php?title=Spektrum_SRXL2
http://manual.spirit-system.com/index.php?title=Spektrum_Integration
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5200
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5210&hilit=Rob
Unfortunately, you have to read the manual step by step and then ask your remaining questions specifically - you will not find anyone here who will completely program your spektrum remote control and set your FBL completely, sorry for saying that, but that's the truth -
I know it's not easy, but everyone has had to go through it -
Where do you come from ? Your English is not very easy to understand - Try Google Translator that helps a lot for the other to understand what you want to -
Users browsing this forum: Bing [Bot] and 4 guests
