Spirit System
No connection of radio Jeti DS-12 with JETI studio
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5100
Author:  ser007 [ Tue 15. Feb 2022 11:34:12 ]
Post subject:  No connection of radio Jeti DS-12 with JETI studio
Hello. I have a problem. I can't connect the Jeti ds-12 radio to the JETI Studio. The VCP driver and Bus/D2XX driver drivers are installed, but virtual COM ports do not appear in the Task Manager. When the DS-12 is connected to a computer, it is defined as a joystick and a removable disk. And in JETI Studio there is no connection with it. Tried on Windows 10 and Windows 8. Can someone help?
Author:  ZeXx86 [ Tue 15. Feb 2022 17:28:47 ]
Post subject:  Re: No connection of radio Jeti DS-12 with JETI studio
it should be enough to only start JETI Studio and then connect DS-12 to your computer.
Then during radio startup select you want to connect to computer with USB.
From this moment JETI Studio should detect the radio.
Author:  ser007 [ Sat 19. Feb 2022 17:53:33 ]
Thanks for your reply.
But the questions remained…
When connecting the Radio, I choose the USB connection.
But the connection does not occur, 1. A transmitter appears in the explorer,
but there are no virtual COM ports in the configuration window, although the drivers are installed.
4. in the lower right corner there is a red cross and a picture of a connection break.
As I already wrote in the Windows device Manager, after installing the drivers, a tab with virtual COM ports does not appear. Maybe someone has faced such a problem?
http://www.phpbb.com/
