It is currently Thu 16. Jan 2025 23:18:29
 Post subject: Spirit 2 setup
PostPosted: Mon 10. Jan 2022 16:06:37
Hi
I have a Spirit 2 unit installed on my Logo 400 heli with a Futaba 14sg transmitter and during setup process I encountered the following problem:
- Step5 went OK with the transmitter sticks moving in the right direction.
-In Step 6 I verified the inputs from the transmitter to swash and rudder and ticked the boxes accordingly. The problem is that with the transmitter inputs everything works OK but when I put the transmitter away and do the verification by moving the heli by hand the swash and rudder are moving in the wrong direction.
Please help
Thank you
 Post subject: Re: Spirit 2 setup
PostPosted: Mon 10. Jan 2022 16:43:14
have you verified that swash type and Spirit unit mounting direction are configured correctly? also be sure to not have any non necessary reverse boxes ticked (in transmitter and Spirit setup). and double-check the servo connections of the swash servos to be like shown.
maybe you could post your setup file and a picture of the Spirit unit mounting on the heli (best incl. swash)...
cheers
Michael
Users browsing this forum: No registered users and 6 guests
