It is currently Sat 21. Sep 2024 18:26:16
[ 6 posts ] |
pabloK
Posted: Sat 28. Feb 2015 15:08:05 |
Hi
I m new for spirit FBL. I think first unit in URUGUAY (South America). I installed it on a new TREX 600L
I made some flights and works fantastic, I will post videos and images soon
Only thing is that I cant use the banks, I cant select any bank, it is always on bank 0 and as grey, not selectable.
I am using rescue acro with DX8 spektrum
thanks for any help
Posted: Sat 28. Feb 2015 15:16:08 |
welcome to our forum!
To enable banks, you have to go in the software to the General tab, then Channels and then select Channel 7 for Banks function. Now you have to save the settings and select the 3-state switch in your transmitter that will change the banks (channel 7). In the diagnostics tab you should see change when you are switching.
Remember that while software is running bank switching is performed via the software. When it is not running bank switching is performed from your transmitter.
pabloK
Posted: Mon 02. Mar 2015 11:00:59 |
Thank you
It is possible to use one channel with 3 position for banks and another channel for the rescue function?
Posted: Mon 02. Mar 2015 11:05:42 |
Yes, this is exactly behavior that is used by default. Rescue is normally activated with Gyro channel while banks are switched with channel 7.
pabloK
Posted: Tue 03. Mar 2015 23:56:25 |
Hi
Works great without any problem
What do you think are good values to start with in each Bank ? I am leraning to fly my first maneuvers like funnel, hurricane and tic tocs, all in a F3C style flight mode I have configured in a two position button the rescue NORMAL mode
Thank you very much again
Posted: Wed 04. Mar 2015 19:17:59 |
mostly it is not necessary to change values between banks at all. If you fly with one settings your learning curve is faster.
You can just try what is the best for you, especially rotation speed (Sensor tab). It shouldn't be too fast or too slow. Mostly values around 10 are fine.
If you can fly inverted, it is better to enable Rescue (Acro).
[ 6 posts ] |
Users browsing this forum: Bing [Bot] and 2 guests |
