[SOLVED] GT Update from 3.3.2 to 3.3.3 problem https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5004 |
Page 1 of 1 |
Author: | JoergZ [ Thu 09. Dec 2021 11:09:40 ] |
Post subject: | [SOLVED] GT Update from 3.3.2 to 3.3.3 problem |
Hi, i have waited long because my GT worked very satisfactorily but it is recommended... after successful update of my newest (unmounted) silver GT i have tried same update of my mounted red GT but this time there goes something wrong: after flashing SpiritSettings says "Success" i reconnect/restart the GT but only showing blinking led (3/sec) without reaction. SpiritSettings do not found I have then tried to recover and SpiritSettings say "success" after flashing process (with GT's led flickering). GT's led shows now solid light. After restart of SpiritSettings the software do not find any unit. (GT still showing solid blue light) Next step i selected SetupWizard with result "Status not found". I then repeated last 2 steps with restarted GT (unpower and repower - GT' led is blinking (3/sec)). Only if i try the way SetupWizzard and come to the point connect GT's led pauses 2 times for a second and restart his blinking (3/sec). I think, i need help regards |
Author: | ZeXx86 [ Thu 09. Dec 2021 11:29:26 ] |
Post subject: | Re: GT Update from 3.3.2 to 3.3.3 problem |
Hello, have you used the latest Spirit Settings for updating too? Or have you tried to flash Aero firmware maybe? I will write you private message with steps to fix the unit. |
Author: | JoergZ [ Thu 09. Dec 2021 11:47:29 ] |
Sorry i forget something. 1) the first thing i did was download a new version of SpiritSettings 3.3.3 today to be save for newest version. 2) my desktop is macbook pro with 10.15.7 Unfortunately, I've only just seen that the battery was already very weak - maybe an undervolting during flashing? I have all repeated with fresh battery but no success. P.S. Thank you in advance |
Author: | JoergZ [ Thu 09. Dec 2021 11:58:16 ] |
Hello again, after GT is now reactivated it is shure that the settings are not errated? regards |
