It is currently Sat 23. Nov 2024 18:20:05
PostPosted: Thu 02. Dec 2021 2:12:08
I recently updated my Jeti Transmitter with version 3.33 Integration.
All of my heli's were working fine using a 6 meter level for auto bailout.
When I checked to see what it was in the Spirit Program running on the Jeti, it was only 1 meter.
It did not matter whether I used 1 meter of 6 meters, the auto bailout was activated at about 7-8 meters.
What changes do I need to make to get the autobailout working properly again?
All the best,
Ken
PostPosted: Thu 02. Dec 2021 7:47:38
Hello Ken
pls read the release notes of 3.3.3 carefully... there is a new process of activation of auto rescue. the height is set at the height you *activate* auto rescue... the parameter in the setting is not for auto rescue height, but for adjustment for inverted flight ("altitude rotor compensation" - normal/inverted will produce different air pressure for the sensor). so what you have changed only will affect auto rescue in inverted flight - pls check carefully if this is OK.
if your Spirit integration still says "rescue height" => pls double check if your integration files have been overwritten in Jeti and all your Spirit units are on 3.3.3
cheers
Michael
Users browsing this forum: No registered users and 23 guests
