Autorotation Bailout rate https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4971 |
Page 1 of 1 |
Author: | helispawn [ Thu 18. Nov 2021 1:16:24 ] |
Post subject: | Autorotation Bailout rate |
Had an incident yesterday on my nitro model where I landed to adjust the tuning and spooled up a short while later and the governor decided I was trying to perform an 'Autorotation Bailout' and did a fast spool up on the ground, tail kicked out, model tipped over and smashed blades. Please explain how to DISABLE 'Autorotation Bailout rate' please! Edit: did some searches, appears throttle needs to be below 12% to disable. Currently my motor idles at 13%, I have played around with the servo end points to ensure idle at <12% to make sure ARB is disabled whenever I hit throttle hold. I do think that there should be an option to completely DISABLE this feature, I doubt that could cause any confusion. Please consider this. |
Author: | ZeXx86 [ Thu 18. Nov 2021 9:08:08 ] |
Post subject: | Re: Autorotation Bailout rate |
You are right, when throttle is that high for idling, it will behave exactly in this way. We will implement it and add new options for setting up bailout. |
Author: | MarkusR. [ Tue 31. Jan 2023 21:57:00 ] |
Hi, Is there a way to turn off the bailout feature? Or is there another way to work around it. FBL is the Spirit GTR. |
