Microspirit Startup https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4940 |
Page 1 of 1 |
Author: | Diogenes [ Thu 21. Oct 2021 22:03:03 ] |
Post subject: | Microspirit Startup |
I now have the following Problem with setting up my microspirit: I want to connect an Spektrum dsmx Satellite with the microspirit. But the Software tells me to connect the Satellite at the Sat Channel and to put a bind plug in the P/E/A Channel. I do not have a bind-plug. What exactly is a bind plug. I can create my own by connecting 2 of the 3 connections of the port right? Which ones do I have to connect? I am just asking for safety reasons I really do not want to damage anything. I guess i need to connect the outer two connectors and leave out the one in the middle? (I am also a bit confused because Microspirit does not have the cable (pole) order I am used to) Thank you for any help! |
Author: | ZeXx86 [ Fri 22. Oct 2021 10:55:46 ] |
Post subject: | Re: Microspirit Startup |
Hello, if you have JST-Servo adaptor, then please plug it in the P/A/E port and there insert a Bind plug. This is only a single wire that is connecting two outer pins together. |
Author: | Diogenes [ Fri 22. Oct 2021 18:26:59 ] |
I understand. Thank you. |
