Spirit System
info about GT altitude
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4898
Author:  urgno [ Fri 17. Sep 2021 10:22:02 ]
Post subject:  info about GT altitude
hello
is possible to see what altitude is detected from spirit GT
when doing tests on bench ?
thank you
Author:  HeliMLM [ Fri 17. Sep 2021 11:59:22 ]
Post subject:  Re: info about GT altitude
there is a minimum of vibration necessary so the GT/GTR is detecting the heli as flying (i.e. mechanics running *without* all blades worked for me)... but then you can go into diagnostics & advances logging features. if you log the altitude there you could see it (will be 0 unless you move it around a bit... mine showed 0 on bench and ~1m when lifted above bench).
Author:  urgno [ Fri 17. Sep 2021 13:36:28 ]
i was hoping there was a real time indication like in geolink status screen
http://www.phpbb.com/
