Spirit System
Stabi Scale function not working with Stabi "Function"
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4852
Author:  Bernhard.F [ Thu 26. Aug 2021 7:53:34 ]
Post subject:  Stabi Scale function not working with Stabi "Function"
For my Scale-Heli I’m using 3 Banks. The only difference is the "Functional Mode" with "separate channel" activated.
Bank2: Stabi (Scale)
Bank3: Rescue
Having the "Function Channel" combined with rescue (Bank 3), rescue works without having the value for the tale stabilisation negative.
For Bank2 Stabi Scale doesn't work, pushing the function only, the Heading Hold continues (visible at the tail blades)
When I switch the stabilisation mode to negative then, the tale blade switch to the expected position and stay there.
It seems negative value is working for Stabi(Scale) mode but not the separate function channel.
I thought the "Function" Channel has the same functionality as the negative gyro gain.
I'm wrong?
Has someone seen the same behavior?
Author:  ZeXx86 [ Mon 30. Aug 2021 13:12:01 ]
Post subject:  Re: Stabi Scale function not working with Stabi "Function"
please take a look at this page:
http://manual.spirit-system.com/index.p ... vs_Channel
There you can see, when Gyro Gain is positive, there will be Head Lock mode for tail, even it is in the Stabilisation mode.
Stabilisation mode will be engaged always, when assigned channel for F: Stabi Function is set to active position. Same apply for Rescue.
But Gyro mode is selected by gyro gain for Scale mode.
Author:  Bernhard.F [ Mon 30. Aug 2021 15:56:20 ]
Hi Thomas,
ok, I hope I got it.
When Function channel is activated, it can activate all stabi modes and rescue in Heading Lock for the tail. Gyro Gain negative has no influence in this modes.
When Scale Mode is selected in a Bank and the Gyro Gain is negative and the Function off, scale flying without stabilisation is selected.
When Scale Mode is selected in a Bank and the Gyro Gain is negative and the Function is on, scale flying with stabilisation is selected.
Thanks and best regard
Bernhard
http://www.phpbb.com/
