It is currently Sat 23. Nov 2024 20:42:40
PostPosted: Thu 14. Oct 2021 12:33:11
:roll: Hello, Recently swith from (Sptkm) to Futuba system,due to the big disappointment with NX series and the really big issue is; how to setup the "simple and easy way" Spirit Rescue into Futuba 18SZ. I'm struggle to get the right setting and hopely some can give some imput/feedback, so I can convert all my 8 units into Futuba system. All advice very much appreciate and thank very-very much.
Cheers ans safe fly. :mrgreen:
PostPosted: Thu 14. Oct 2021 13:46:15
do you have single line receivers ?
or still use the old pwm connection ? ( multiple cables )
PostPosted: Wed 27. Oct 2021 12:35:37
:| Sorry mate, for thr delayed respond. Yes single line futuba sbus connection. Thanks you mate.
PostPosted: Wed 27. Oct 2021 12:40:48
The simplest way is to set a momentary switch as a Gyro Gain driver.
For one position you will set for example 60% AVCS and when rescue should be engaged then 60% NORM.
In the Spirit Settings it is enough to set Stabi/Function to Rescue.
PostPosted: Tue 02. Nov 2021 3:14:42
:D Thank you mate, going to try it out and will give you guys a feedback. Thank you all..! Cheers. :D
PostPosted: Tue 02. Nov 2021 10:09:08
having s.bus connection between receiver and spirit
and having plenty of channels on the 18sz ;-)
you can even use a dedicated channel on the TX
I use channel 11 assigned to 2 position
spring-loaded switch SH on my T16sz
Users browsing this forum: mainstreet and 32 guests
