ZeXx86 wrote:
Quote:
Therefore as I mention before the Rescue function must be around during 1-2 Second,
Because the Rescue function lift the Heli only few Meters, even if you put 15º Positive Pitch.
It is enough to set around 60 - 80% for pitch. The model should ascend always to configured altitude.
Quote:
Yes but I already I write you nearly three weeks ago, that all my Helis are 100% Mechanical setup, 180ª = 0º Pitch 12,5+ and 12,5 – , no Tracking at the Blades
This does not mean your setup is correct unfortunately. You can achieve these settings even with a wrong steps. Can you please verify that all 3 particular steps are correct?
Quote:
My answer: Yes in every Altitude, but there is an Altitude Bug for sure .
Please note, Altitude Limit and Altitude Hold function is there for over 2 years. People are using it daily. We only have to find what problem is in your configuration. I think it is related to zero pitch degree configuration which could be also related to the previous question. You can find videos on YouTube how it is working. I am sure it will work also for you.
Quote:
Please show me , because the point I cannot move it in the Software, on the GT with GeoLink.
Here you can see my attachment. GeoLink enabled with Spirit GT and Flight Style is configured, even for 3 banks. I guess you assigned P: Flight Style in the Channels window but you forgot about it. Now it is always overwritten with channel value. It seems you are trying to configure too much things. It is important to understand first how each particular thing is working before configuring everything and then thinking it is bug.
Quote:
I already mention before that I see on the GeoLink Aid Tab switch ( Channel works) but on the GT no, and in case that the channel value is not good, why I see it on the software working when I switch in the Transmitter. Why you not up to date a little bit the Manual, even the Port using on the GT for the GeoLink is not stated there.
It is important that in the Channels window you will see 2 or 3 mode for Return to Home. Function 2 is programming for all 3 banks, while function 3 is programming only single, selected bank.
We are updating manual each day, it is not easy to do it immediately, because there are many, many pages in multiple languages. And people are asking questions for whole day or they are very impatient for products to ship. We are working 16 hours each day. Unfortunately it can't be faster. At the same time we are preparing new products and new firmwares.
My answer: That’s means if the configured altitude is 8 meters, that the Heli in case falls to aprox. 3 meters over the ground , and after that ascend only to the 8 meters?
My answer: : I mention now for 5-6 times that the Technicall Setup of the Heli is 100%.
My answer: Also with GeoLink your answer is not Logical, because when a Heli Flight perfect,
That’s mean enough Pitch to ascent ect. Then when is the Function Altitude Hold active, the GeoLink receive the info from the Pressure Sensor or and from the GPS for compensate and Hold the altitude , also for my Logical understanding, it is doesn’t matter if the Heli even have only 6º Pitch maximum positive, because the information send from the GeoLink to the “GT”, Will say ascend the Heli until pre-programmed altitude is reached or and maintained.
My answer: Now it works ??
My answer, what you mean with “2 or 3 mode for Return to Home”?? Also when I setup on the Channel window, you can choose only one time the Function “Return to Home”
And in my case why the programming function for “ new Returning home Position “ not works , even if I see it on the Aid window GeoLink Working?? I know and understood you perfectly and have the same , because I have a few Companies too, but in your case looks you make it more difficult than it is. Because before bring out a new product , you have to make a Detailed Manual , starting for Channel assignation ( All the Manufactures Futaba , Spektrum ect., Main Setup, Special Setup with Gyro Gain, Functions, ect ect. Then you do not have Clients asking all the day basic questions, that’s safe a lot of time and work.
But I have still the same problem now for nearly 4 week’s, I have some Test Flight yesterday , and in my case still the same , on the bench before I take off all the GeoLink Functions works two Blue Leds steady on”GT and GeoLink”, but after landing I put it directly on the bench again, Geolink functions not works !?? Also in middle of the Flight not work’s too! ??
