It is currently Sat 23. Nov 2024 20:31:32
Post new topic Reply to topic  [ 17 posts ]  Go to page 1, 2  Next
PostPosted: Tue 10. Aug 2021 13:51:43
Transmitter: Radiomaster TX16S with Multimodul and firmware 1.3.2.86
Receiver: Frsky X8R with ACCST D16 FCC protocol
Spirit GT with firmware 3.3.2
The Spirit has problems to initialize, 1 of 3 attempts fail.
PostPosted: Tue 10. Aug 2021 13:53:53
Can you describe how it will fail? Is it same as your collegue - by wrong channel centering?
PostPosted: Tue 10. Aug 2021 14:15:10
No, it does not initialize. The blue led does not blink at start, it is permanently on. The servos are not responding. All is dead.
PostPosted: Tue 10. Aug 2021 21:41:32
In that case I will send you guide for fixing the problem in private message.
Solution should be easy.
PostPosted: Wed 11. Aug 2021 7:10:54
Did you send me a message? I did not receive a message.
PostPosted: Wed 11. Aug 2021 11:05:30
Yes, now it was sent to you with instruction.
PostPosted: Wed 11. Aug 2021 14:12:40
I have the same problem, sometime, not often, the blue led is solid and no servo movement is possible. The YGE ESC does not initialize, i hear no peep tone from the ESC.
I have a Ultra Guard parallel connected. The behavior is too rare that it makes sense to disconnect the Ultra Guard.
PostPosted: Wed 11. Aug 2021 16:30:58
Thank you, now with the new bootloader it works.
PostPosted: Thu 12. Aug 2021 9:36:32
No, the problem persists also with the new bootloader
PostPosted: Thu 12. Aug 2021 9:51:09
Can you describe your full setup please?
You said it is appearing 1 from 3 times. Today is it same again?
