[SOLVED] Spirit GT 3.3.2 not initializing https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4821 |
Page 1 of 2 |
Author: | weixelgeist [ Tue 10. Aug 2021 13:51:43 ] |
Post subject: | [SOLVED] Spirit GT 3.3.2 not initializing |
Transmitter: Radiomaster TX16S with Multimodul and firmware 1.3.2.86 Receiver: Frsky X8R with ACCST D16 FCC protocol Spirit GT with firmware 3.3.2 The Spirit has problems to initialize, 1 of 3 attempts fail. |
Author: | ZeXx86 [ Tue 10. Aug 2021 13:53:53 ] |
Post subject: | Re: Spirit GT 3.3.2 not initializing |
Can you describe how it will fail? Is it same as your collegue - by wrong channel centering? |
Author: | weixelgeist [ Tue 10. Aug 2021 14:15:10 ] |
No, it does not initialize. The blue led does not blink at start, it is permanently on. The servos are not responding. All is dead. |
Author: | ZeXx86 [ Tue 10. Aug 2021 21:41:32 ] |
In that case I will send you guide for fixing the problem in private message. Solution should be easy. |
Author: | weixelgeist [ Wed 11. Aug 2021 7:10:54 ] |
Did you send me a message? I did not receive a message. |
Author: | ZeXx86 [ Wed 11. Aug 2021 11:05:30 ] |
Yes, now it was sent to you with instruction. |
Author: | Storchy [ Wed 11. Aug 2021 14:12:40 ] |
I have the same problem, sometime, not often, the blue led is solid and no servo movement is possible. The YGE ESC does not initialize, i hear no peep tone from the ESC. I have a Ultra Guard parallel connected. The behavior is too rare that it makes sense to disconnect the Ultra Guard. |
Author: | weixelgeist [ Wed 11. Aug 2021 16:30:58 ] |
ZeXx86 wrote: Yes, now it was sent to you with instruction. Thank you, now with the new bootloader it works. |
Author: | weixelgeist [ Thu 12. Aug 2021 9:36:32 ] |
weixelgeist wrote: ZeXx86 wrote: Yes, now it was sent to you with instruction. Thank you, now with the new bootloader it works. No, the problem persists also with the new bootloader |
Author: | ZeXx86 [ Thu 12. Aug 2021 9:51:09 ] |
Can you describe your full setup please? You said it is appearing 1 from 3 times. Today is it same again? |
