It is currently Sat 23. Nov 2024 20:34:39
Page 1 of 1
[ 4 posts ] |
Author |
Message |
JoergZ
Posted: Mon 19. Jul 2021 19:52:05 |
Joined: Wed 09. Jun 2021 8:51:13 Posts: 30 Location: NRW Germany
Hello, if collective direction is set on reversed the pitch runs in the negative (wrong) direction during rescue (no matter which). When the rescue is triggered, the helicopter sinks towards the ground at the set pitch rate (with a negative value).
Only if the collective direction is not set is the rescue pitch correctly in the positive range.
The cyclic pitch runs correctly in both settings.
Please correct, Thank you very much
P.S. this error has already been mentioned in a post, but not in connection with the setting Advanced / Collective Direction
Top |
Posted: Mon 19. Jul 2021 21:44:01 |
Site Admin |
this tick is not for changing collective pitch. This is for telling the unit your model has reversed mechanics, such as Blade helicopters.
Please do not confuse it with channel reversal.
Top |
JoergZ
Posted: Mon 19. Jul 2021 22:31:26 |
OK. That wasn't clear. Setting of collective direction pitch to reversed synchronizes direction with my TX and a checkbox for the direction of rescue pitch would be perfect. Maybe as an idea ... Thanks
Top |
Posted: Tue 20. Jul 2021 12:31:02 |
Site Admin |
It is incorrect to change rescue direction. Instead it is correct to proceed according Setup Wizard which will result that all features will work well, in right direction, including Rescue. If Rescue is working in opposite direciton it mean that base setup is very wrong and you should not fly in any case. Also some other things will not work correctly in this case.
Top |
Page 1 of 1
[ 4 posts ] |
Who is online |
Users browsing this forum: No registered users and 39 guests |
