It is currently Sat 23. Nov 2024 23:02:09
PostPosted: Sat 17. Jul 2021 15:37:38
I am uing Bank swtiching to set Stabi - Coaxial on my Goblin 500.
When in Bank 0 I am set up for 10 degrees of pitch, pos/neg.
When I select Bank 1 = Coaxial Stabi, then the pitch jumps to 5 degrees of Positive pitch if i am full pitch.
Anyone have a clue what setting I need to change to fix this or is this expective behaviour?
PostPosted: Mon 19. Jul 2021 7:56:46
it is enough to set Collective Pitch Range in the Limits tab to the same value as for Bank 0. Then it will work.
PostPosted: Mon 19. Jul 2021 9:34:25
Thanks so much!
Issue is resolveds 8-)
Users browsing this forum: Bing [Bot] and 57 guests
