Spirit System
[SOLVED] Spirit 2 not initilizing in 3.3.1 after upgrade
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4775
Author:  Jojo [ Sun 18. Jul 2021 11:22:54 ]
Post subject:  [SOLVED] Spirit 2 not initilizing in 3.3.1 after upgrade
I have upgraded firmware on my Spirit 2 with latest and it doesn't anymore start up normally.
Goes into Blue Led blinking mode and i can't anymore connect via USB nor via Jeti TX.
Only if i flash again same firmware it works, but if power off Spirit , it doesn't initiate when i power it up.
Tried the old firmware but same issue, i have never had this issue with any spirit modules.
Can i get help to fix this?
Author:  ZeXx86 [ Mon 19. Jul 2021 7:51:43 ]
Post subject:  Re: Spirit 2 not initilizing right in 3.3.1 after upgrade
please send .spirit-flash.cfg file to a private message or our email. With this file we will be able to fix the problem.
I will send you all instructions.
Author:  Jojo [ Mon 19. Jul 2021 12:05:35 ]
Its sent via PM
Author:  Moki38 [ Tue 31. Aug 2021 8:55:03 ]
Same here, Same Spirit2, Same firmware, same result -> Bricked Spirit2
Did a search for the file (.spirit-flash.cfg), can't find it..(W10).
But i have multiple units, does it get overwritten?
Author:  ZeXx86 [ Wed 01. Sep 2021 9:00:54 ]
The issue was resolved after our private conversation with special firmware. We recommend to use the latest Spirit Settings for updating the units.
http://www.phpbb.com/
