[SOLVED] Mechanical Mixing https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=477 |
Page 1 of 1 |
Author: | FlyboyPeter [ Thu 19. Feb 2015 13:22:07 ] |
Post subject: | [SOLVED] Mechanical Mixing |
Hi People Can the Spriit be used with a heli with mechanical mixing, had a good look at the manual and it does not appear to support mech mixing, but I could be wrong. Was looking to fit one to a Raptor... best regards Pete |
Author: | ZeXx86 [ Thu 19. Feb 2015 13:47:03 ] |
Post subject: | Re: Mechanical Mixing |
Hi, you can set CCPM 90/120/135/140° and also set cyclic phase angle for multirotor heads. What Raptor do you fly? |
Author: | FlyboyPeter [ Thu 19. Feb 2015 23:28:37 ] |
Hi and Thanks for the reply. It is the old raptor 50 Se. I assume that 90 deg is for the mech mixing. ( ie seperate pitch/roll/elevator servos). best regards Peewee |
Author: | FlyboyPeter [ Fri 20. Feb 2015 20:24:27 ] |
Hi people Can anyone tell me if I can use the Spirit on a mech mixed swash like a Raptor. Best regards PETE |
Author: | ZeXx86 [ Fri 20. Feb 2015 20:34:57 ] |
Spirit support 90° mechanical mix. It should work with 3 cyclic servos and rudder servo. |
Author: | FlyboyPeter [ Sat 21. Feb 2015 11:06:20 ] |
Thanks for the great support Buying shortly Best regards Pete |
