Spirit System
GT initializing
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4761
Page 1 of 4
Author:  10x [ Sat 10. Jul 2021 19:38:47 ]
Post subject:  GT initializing
Hello Tomas
Slight problem with my GT. The 1st time i connect the receiver battery some times the GT just puts the blue led on with no flash and does not initalize and nothing works.
If i disconnect the battery and plug in right away the led flashes and it all works ok....If i carry on conecting and disconecting battery it initializes evey time, but if i leave it for a while
it goes back to not starting. If it is starting ok all works well and flies good. Just a bit concerned....Jeti DS12 with Rex3 and Spirit GT...
Regards Adrian
Author:  pho [ Sat 10. Jul 2021 20:20:08 ]
Post subject:  Re: GT initializing
I have observed exactly the same.
Ds14, Rex3
Sometimes it takes 2 Power up cycles to init GT.
If it is up... everything works fine
BR
Philip
Author:  HeliMLM [ Sat 10. Jul 2021 20:38:56 ]
how is the setup of the Rex3?
Author:  heri [ Sat 10. Jul 2021 21:37:01 ]
i have the same problem with my futaba t14sg via s-bus.
Heri
Author:  10x [ Sat 10. Jul 2021 22:10:52 ]
Output Period = 17ms
ppm/udi mode = direct
fail safe delay = 1.5s
2/E1 = exbus
Not sure if you mean any other details....
Just to add i am using life battery for receiver/spirit...
Author:  HeliMLM [ Sun 11. Jul 2021 9:55:20 ]
i've not seen this happen to my GT so far. i am using 10ms and failsafe off (= to be done by Spirit unit) on all my Spirit units. i powered it either by 4xEneloop or 2s LiPo on bench and later directly out of YGE Bec (7.7V).
did you check the Spirit log when this happened? there should be some entry telling "why" it is not initializing... (and maybe: is Jeti telemetry already working correctly at this time? receiver correctly bound and responding? Spirit telemetry items?)
Author:  10x [ Sun 11. Jul 2021 10:25:00 ]
I have now changed rx to 10ms, telementry from jeti rx all working but not from GT, Will wait awhile and retest, when starts up ok log reports all good...
Author:  rotorhead51 [ Sun 11. Jul 2021 14:53:39 ]
I have the same issue as well!
Futaba 18SZ, S-Bus with R7008SB receiver, running off a 2S lipo.
Author:  ZeXx86 [ Mon 12. Jul 2021 7:44:27 ]
Can you let me know if you have RealTime logging enabled? Also you can share your settings file please so we can find the problem.
Author:  10x [ Mon 12. Jul 2021 8:12:28 ]
Yes for real time logging and file attached...
Rufus E755.4ds [255 Bytes]
Downloaded 47 times
Page 1 of 4 All times are UTC + 1 hour
http://www.phpbb.com/
