ZeXx86, I tried the settings you suggested. It did help a little, but I had to increase settings a bit. Here is where I am now.
I have the Rudder Gain at 85% Revomix is at 7 Pirouette Consistency is at 190.
At these levels the tail blowout is almost gone, still there, but minimal. I may increase Revomix to 8. The tail still has a little bit of wag at times, but almost gone. My concern is, I am starting to get a little bit if oscillations. For example, if I am descending quickly, and stop descent with a pitch increase, the tail will oscillate a little. Also at any abrupt change of direction, it will oscillate. These oscillations are minimal, but I feel with more aggressive maneuvers, oscillations could be worse.
I would also like to remind that my heli is set up relatively mild. I am running 2500 headspeed, and only about 9 degrees of pitch. I do not know how this affects the setup. What is the reason for the increased effort in setup for the OXY 4 Max that you indicate? I do have the ball links correctly sized, and also the pitch slider, linkages, and tail grips move with no resistance. It really is smooth from endpoint to endpoint. I know you suggested that KST servos can require special settings. Would you suggest another servo in it's place? Any other suggestions?
Thank you ChrisM
