[SOLVED] telem uni cable homemade https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4698 |
Page 1 of 1 |
Author: | Anton38357 [ Mon 07. Jun 2021 7:21:17 ] |
Post subject: | [SOLVED] telem uni cable homemade |
Should be a quick one to answer... Just bought a few things from the online Spirit FBL shop and forgot to add the Telem Uni Cable Can a normal JST-RX adaptor still be used with the Spirit Pro and Spirit V2 just with the red (middle) cable removed? Hope to hear from someone.. |
Author: | ZeXx86 [ Tue 08. Jun 2021 21:29:42 ] |
Post subject: | Re: telem uni cable homemade |
Yes, you are right. Red wire disconnected. Otherwise it could burn unit. |
Author: | azaz44 [ Sat 03. Jul 2021 11:40:44 ] |
Having same problem here. I'm switching the ESC and just need Telem Uni. Did it work for you Anton? What is then a difference? Telem Uni seem to have some PCB inside, so is it not needed at all? |
Author: | Anton38357 [ Mon 05. Jul 2021 7:56:42 ] |
Nope, you don’t need the bought one. Home made works perfectly fine. It looks like a pc board, however just a 3 in, two out. Recap, just snip the positive wire - all good. |
Author: | azaz44 [ Thu 15. Jul 2021 22:32:41 ] |
Post subject: | Re: [SOLVED] telem uni cable homemade |
Thanks, I did it and it works fine. |
