It is currently Sun 24. Nov 2024 0:57:05
PostPosted: Sat 22. May 2021 18:22:25
I want to have easy acess to all the spirit parameters without going thrue allé the menus and the config file is a binary format.
This URL does not work with the latest version http://4dsviewer.spirit-system.com/www/
Will the site be updated or is they’re a easy fast way to see all the parameters on the screen ?
PostPosted: Sat 22. May 2021 19:26:16
+1
PostPosted: Sat 22. May 2021 20:20:42
You can load a saved profile into a version 3.1.0 Spirit Settings, save the 3.1.0 version of the profile and then use 4dsviewer to display the parameters. It does not give you the newest parameters, but it is better than nothing.
PostPosted: Sun 23. May 2021 2:36:58
Humm, can you tell me more on how to do this ? I don’t see a save in older version menu…
PostPosted: Sun 23. May 2021 16:51:32
You save a Profile data file from Spirit Settings. Then copy this Profile data file to a computer that has v3.1.0 Spirit Settings installed. Then you run the v3.1.0 Spirit Settings in Demo Mode. Load the Profile data file on the Backup tab, and then save it to a different v3.1.0 Profile data file. You can then view this v3.1.0 Profile data file in the 4dsviewer. If you don't have it, you can get the v3.1.0 Windows Spirit Settings from the following link:
https://www.spirit-system.com/dl/settin ... -win32.exe
PostPosted: Mon 24. May 2021 2:46:51
Thanks « FrankFuss » for thé idea and the version, I will use it .
PostPosted: Mon 24. May 2021 15:43:18
The older version worked and i saved the new config with the older version...
But.... i received the following error when i tried to run the file : index receiver_values and value 6 not found
I hope Thomas can do something about it.
PostPosted: Tue 25. May 2021 16:58:45
I don't know why you got that error. It works for me.
Users browsing this forum: No registered users and 61 guests
