It is currently Sun 24. Nov 2024 1:39:58
PostPosted: Tue 18. May 2021 10:59:33
Hi, I have problem: when i want to see a flight log under "diagnostics" tab on my Android smartphone, I'm asked to choose Storage directory to save my log, but when I tap on that, the Wifi-link disconnects and that's it...I can only go reconnect and start over to no avail.
All other stuff - all unit settings and also vibration analysis & bec tester seems to be working properly with Wifi-link & android system.
Wifi-link wiring connections to the FBL units are made as per manual instructions.
My units are Spirit 2.
The firmware I run on them is v3.2.1
The android app "Spirit settings" is v3.2.0
Ideas please!
PostPosted: Tue 18. May 2021 14:11:52
I have the same problem. Can't change directory, and the wifi link disconnects every time when I try it... :(
Jeti DS12, Align T-Rex 470L with Spirit GTR, Soxos Strike 7 with Spirit GTR
PostPosted: Wed 19. May 2021 18:12:42
So this one really looks like a bug. I've also tried it using my wife's phone and result is the same. When I tap to choose directory to save logs, it just disconnects.
So Tomas, can this issue be looked into please?
PostPosted: Thu 20. May 2021 11:31:27
it is needed to allow storage access in the Android settings. So then it will be able to access the directory and you can choose it.
PostPosted: Thu 20. May 2021 15:57:35
It works. Thank you!
Users browsing this forum: No registered users and 52 guests
