Unable to see data-log using Wifi-link on phone (Android) https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4675 |
Page 1 of 1 |
Author: | TomazBernik [ Tue 18. May 2021 10:59:33 ] |
Post subject: | Unable to see data-log using Wifi-link on phone (Android) |
Hi, I have problem: when i want to see a flight log under "diagnostics" tab on my Android smartphone, I'm asked to choose Storage directory to save my log, but when I tap on that, the Wifi-link disconnects and that's it...I can only go reconnect and start over to no avail. All other stuff - all unit settings and also vibration analysis & bec tester seems to be working properly with Wifi-link & android system. Wifi-link wiring connections to the FBL units are made as per manual instructions. My units are Spirit 2. The firmware I run on them is v3.2.1 The android app "Spirit settings" is v3.2.0 Ideas please! |
Author: | Frigetrus [ Tue 18. May 2021 14:11:52 ] |
Post subject: | Re: Unable to see data-log using Wifi-link on phone (Android |
I have the same problem. Can't change directory, and the wifi link disconnects every time when I try it... |
Author: | TomazBernik [ Wed 19. May 2021 18:12:42 ] |
So this one really looks like a bug. I've also tried it using my wife's phone and result is the same. When I tap to choose directory to save logs, it just disconnects. So Tomas, can this issue be looked into please? |
Author: | ZeXx86 [ Thu 20. May 2021 11:31:27 ] |
Hello, it is needed to allow storage access in the Android settings. So then it will be able to access the directory and you can choose it. |
Author: | TomazBernik [ Thu 20. May 2021 15:57:35 ] |
It works. Thank you! |
