It is currently Fri 22. Nov 2024 8:24:24
PostPosted: Sun 08. Feb 2015 12:43:27
hi I'm having problems connecting the unit to my nexus 7 tablet. I'm using the adaptor that was purchased with the fbl system.
Both the tablet software and fbl software are the most current version.
I can pair the device to my tablet no problem blue light goes from blinking to solid once I've clicked connect in the app.
Tone of the servos change slightly but it still shows as disconnected on the status bar I've reset my tablet and repaired the module but I can't seem to get the status to change.
Can anyone shed any light as to what I might be doing wrong nexus7 is the only android device, is this device even compatible? my mobile is an iPhone which i don't think has the app as I've searched but can't find. Cheers
PostPosted: Sun 08. Feb 2015 12:49:26
you can recheck if connection to SYS port is correct. I guess that the problem is there.
It works with Nexus 7 pretty well.
PostPosted: Sun 08. Feb 2015 14:56:09
Hi it's working was working all along I was expecting the status to refresh and show connected but once I went back to the menu screen it showed it as connected.
One other question can you edit different banks with the app or on pc only ?
PostPosted: Sun 08. Feb 2015 15:02:12
Great. You can use Bank switching with Mobile app without any issue.
Check this page: viewtopic.php?f=20&t=308
PostPosted: Sun 08. Feb 2015 17:41:29
Many thanks
Users browsing this forum: Bing [Bot] and 25 guests
