Spirit System
Tail sensitivity
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4658
Author:  Bill-kraken-700 [ Sun 02. May 2021 17:20:47 ]
Post subject:  Tail sensitivity
Hi after making a few adjustments to my spirit pro and getting heli flying good. I now have the problem that the rudder is to sensitive. What setting do I reduce to slow it down
Author:  FrankFuss [ Sun 02. May 2021 18:02:46 ]
Post subject:  Re: Tail sensitivity
You reduce the sensitivity of the Rudder stick at center by adding rudder expo on your transmiter. Also, you want to adjust the maximum Rudder Rotation Speed to your liking on the Sensor tab.
Author:  Bill-kraken-700 [ Sun 02. May 2021 21:44:42 ]
I was lead to believe not to use the expo on flybarless systems?
Author:  aziz76 [ Tue 04. May 2021 4:42:33 ]
Trim is what you shouldn’t use. Expo is fine. I run 20% on cyclic and 50% on rudder. Makes things softer/more precise around center. But you should also look at you rudder or yaw rate and be happy with your maximum rotation rate.
http://www.phpbb.com/
