Spirit System
Alarm S vibes
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4640
Author:  Helikapoter [ Tue 13. Apr 2021 23:43:31 ]
Post subject:  Alarm S vibes
I got the screen with a alarm : Alarm : S vibes < 30% (0)
I have no clou what it means ? :?:
Using a Spirit RS and DS12
Regards , Arno
Author:  vvv850 [ Wed 14. Apr 2021 7:13:37 ]
Post subject:  Re: Alarm S vibes
This is an external telemetry sensor, from your FBL. The alarm means that the level of vibrations measured by Spirit went over 30%.
I don't know if this is a default alarm created automatically when using the Jeti wizard for Spirit, or you created the alarm in the past.
Author:  buttles [ Wed 14. Apr 2021 8:25:36 ]
It may be a typo in the firmware but that alarm is saying vibes LESS than 30%. Look in the alarms section on the Tx and check what has been set. I would expect to see >30%. I set a number 10% more than my recorded vibes.
Author:  ZeXx86 [ Mon 19. Apr 2021 13:54:07 ]
you can delete this alarm. It does not make a sense, because it will trigger whenever vibrations are under 30%. Likely you created it by mistake.
http://www.phpbb.com/
