It is currently Sat 23. Nov 2024 23:36:43
 Post subject: 6 Degree Tuning Problem
PostPosted: Mon 12. Apr 2021 13:06:42
I’ve set up several Spirits (mine and friends) and I’m having an issue with 6 degree tuning for the first time.
I cannot get more than 5.2. I keep increasing the value and it just stops increasing in degrees around 110 value.
My rates are 100, swash is level, and I’ve even raising/lowering the swash a little and zeroing the blades at neutral stick.
Nothing seems to work even after looking at the mechanical side of things. Please help (Blade 330)
PostPosted: Sat 17. Apr 2021 9:11:12
Hi, I had this same problem when setting up a black nitro using gwd servos, turned out 1 servo wasn't centering correctly, it sent the whole setup out of whack, I had to connect a separate servo centerer to get it right even though the spirit software centered everything initially.
Hope this helps
Users browsing this forum: Amatrix and 39 guests
