It is currently Sun 24. Nov 2024 0:46:24
PostPosted: Wed 30. Dec 2020 2:15:33
I want to connect telementry for Futaba 14SG (Futaba R7008SB) and Hobbywing Platinum 60A V4 ESC
It would work with Spirit 2 with Frsky Cable?
http://manual.spirit-system.com/index.p ... _Telemetry
Telemetry from Platinum 60A V4 ESC I make like this, with Telem UNI cable?
Thanks for help. I'm not sure, because I found only information about Spirit 1 :(
Best,
Jacek
PostPosted: Wed 30. Dec 2020 8:22:38
yes, you are right. You will need both cables to make it work together.
PostPosted: Thu 01. Apr 2021 17:58:03
I have connected everything. Futaba see correcly a telementry and a RPM information. I have problem with FBL unit, becouse I checked via android app and rpm value is 0 (maybe for a moment I see 400-700 and it change to 0). For clear I tell you, the classic RPM sensor cable from ESC is disconnected from Spirit 2 unit.
Previously when I have connected RPM sensor cable from ESC directly to FBL unit, I have seen values.
Could you help me?
PostPosted: Thu 01. Apr 2021 20:48:50
what about other telemetry values?
For example Battery Voltage?
Is your ESC updated to the latest firmware (but not for VBar)?
PostPosted: Thu 01. Apr 2021 21:39:32
All telementry read from spirit 2 in Futaba works fine, RPM too. Problem is only with value in governor RPM metter in governor setting, because of zero.
ESC is uptodate. Please take a look in attachments.
PostPosted: Thu 01. Apr 2021 21:48:19
This is all correct. You can't use RPM value from telemetry for governor. Spirit app is showing data from sensor, but there is no RPM sensor connected.
PostPosted: Thu 01. Apr 2021 21:50:40
Aaaa. How can I connect rpm sensor, becouse of this port is used for frsky interface for futaba :D
PostPosted: Thu 01. Apr 2021 21:53:55
You can add wire from the ESC in the middle position. This is unused. You can use connector from the FrSky integration cable. Or change servo connector to a single pin plastic. Then you can connect and disconnect both separately.
PostPosted: Thu 01. Apr 2021 21:59:18
I added in the middle position. Thanks! Works great, my Master :)
Users browsing this forum: Bing [Bot] and 53 guests
