Geolink distance from Tail servo https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4532 |
Page 1 of 1 |
Author: | Storchy [ Mon 08. Feb 2021 16:06:04 ] | ||
Post subject: | Geolink distance from Tail servo | ||
I want to mount the geolink on a small Lynx Oxy 3 The distance is only 6 cm The servo is a Nexspor CLS2305T see data https://www.nexspor.com/ Thanks for your help
Author: | ZeXx86 [ Tue 09. Feb 2021 21:51:36 ] |
Post subject: | Re: Geolink distance from Tail servo |
Hello, it should work well. You can try to move servo or GeoLink and observe GeoLink Heading angle. If value will not change, then it should be still safe. |
Author: | Storchy [ Wed 10. Feb 2021 8:53:15 ] |
Many thanks for your response. So I have now tested the following: I moved the geolink back and forth on the boom and the angle only changed 1-2°. I assume that I also moved the helicopter a little while moving it, so this is ok. I'm trying to mount the Geolink as close as possible to the servo. I want to reduce the "heavy load" on the boom as much as possible, it is a very small helicopter. If I understand the manual correctly, the accuracy of the geolink compass has no effect on flight behavior. but only on the exact position at the RTH function . Holding attitude is also unaffected. Is this right? Thanks a lot Jörg |
Author: | ZeXx86 [ Wed 10. Feb 2021 9:13:34 ] |
Yes, you are perfectly right. |
