Spirit System
S.Port Integration with R161 Receiver
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4528
Author:  BenLeo [ Fri 05. Feb 2021 6:31:54 ]
Post subject:  S.Port Integration with R161 Receiver
Hi guys,
Looking for some help on wiring a Radiomaster R161 S.port wire from the molex to an Frsky integration cable. Can this be done and if so what's the best way to wire the s.port wire to the integration cable?
On my larger frsky receivers with a dedicated S.port this is not an issue.
Flybarless unit is S2
Thanks for your help.
Author:  stefaanbolle [ Fri 05. Feb 2021 8:38:14 ]
Post subject:  Re: S.Port Integration with R161 Receiver
You have to solder a custom cable from which you take the S.Port and the + and GND to a female JR connector to put it on the integration cable.
+ => + to FBL and + to Integration cable
GND => GND to FBL and GND to Integration cable
S.BUS => S.BUS to FBL
S.PORT => S.PORT to Integration cable
RSSI => not used
Author:  BenLeo [ Fri 12. Feb 2021 1:16:32 ]
Thank you!
http://www.phpbb.com/
