It is currently Sun 24. Nov 2024 6:57:41
 Post subject: Align ESC RPM wire
PostPosted: Tue 02. Feb 2021 19:44:45
My Align ESC has a yellow RPM signal wire. Can this be plugged into the spirit?
 Post subject: Re: Align ESC RPM wire
PostPosted: Wed 03. Feb 2021 8:25:43
Yes, you can plug it in. But wire must be moved at the middle pin in the servo connector.
PostPosted: Wed 03. Feb 2021 21:36:20
thanks. Which port should I use? Aux?
PostPosted: Thu 04. Feb 2021 10:52:06
PIT pin as with any other RPM sensors, please see manual.
http://manual.spirit-system.com/index.p ... e=Governor
Users browsing this forum: The Gasman and 33 guests
