It is currently Sun 24. Nov 2024 6:33:26
PostPosted: Mon 08. Feb 2021 16:06:04
I want to mount the geolink on a small Lynx Oxy 3 The distance is only 6 cm
The servo is a Nexspor CLS2305T see data https://www.nexspor.com/
Thanks for your help
PostPosted: Tue 09. Feb 2021 21:51:36
it should work well. You can try to move servo or GeoLink and observe GeoLink Heading angle.
If value will not change, then it should be still safe.
PostPosted: Wed 10. Feb 2021 8:53:15
Many thanks for your response.
So I have now tested the following:
I moved the geolink back and forth on the boom and the angle only changed 1-2°.
I assume that I also moved the helicopter a little while moving it, so this is ok.
I'm trying to mount the Geolink as close as possible to the servo. I want to reduce the "heavy load" on the boom as much as possible,
it is a very small helicopter.
If I understand the manual correctly, the accuracy of the geolink compass has no effect on flight behavior.
but only on the exact position at the RTH function . Holding attitude is also unaffected.
Is this right?
Thanks a lot
Jörg
PostPosted: Wed 10. Feb 2021 9:13:34
Yes, you are perfectly right.
Users browsing this forum: No registered users and 31 guests
