Update 3.2.2 https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4515 |
Page 1 of 5 |
Author: | Manfred [ Sun 31. Jan 2021 19:54:51 ] |
Post subject: | Update 3.2.2 |
Hello, updated my Radio DS 16 and Spirit RS to 3.2.2. If i use now the device explorer to RS the screen jumps allways back after a couple of seconds to the device explorer. What is wrong ? Best Manfred |
Author: | ZeXx86 [ Sun 31. Jan 2021 20:13:57 ] |
Post subject: | Re: Update 3.2.2 |
Hello, can you check if serial number of the unit ends with -a1 in the Connection tab, Spirit Settings? Also have you updated BIN file in the Devices directory (radio)? |
Author: | Manfred [ Sun 31. Jan 2021 20:29:51 ] |
Hi, Yes to both. Serial ends with.... 55-a1 Updated Spirit.bin to newest Version. Best Manfred |
Author: | ZeXx86 [ Sun 31. Jan 2021 20:33:28 ] |
Great. Is something connected in the E2 port of the Spirit RS unit? It seems connection is somehow unstable. By connecting something in the E2 it can cause such troubles, because E2 is used for data transmission in normal configuration. |
Author: | Manfred [ Sun 31. Jan 2021 20:38:11 ] |
Hi, no, E1 and E2 are not in use. Best |
Author: | ZeXx86 [ Sun 31. Jan 2021 20:41:05 ] |
Thank you. Could you please share your settings? Preferably 4ds file. Tomorrow we can verify behavior with the settings and let you know. I believe it can be resolved easily. But we never encountered such behavior. |
Author: | Manfred [ Sun 31. Jan 2021 20:46:53 ] | ||
Post subject: | Re: Update 3.2.2 | ||
many Thx. Here you are. Manfred
Author: | ZeXx86 [ Mon 01. Feb 2021 8:24:35 ] |
Thank you. We have not found anything strange in the settings. It is working perfectly with our untis. Maybe you have opened Spirit Settings at the same time as the integration? If you will access Spectrum Analysis there then it will close the integration. This is correct behavior. |
Author: | Manfred [ Mon 01. Feb 2021 19:28:16 ] |
Hi, no, no use of connection on same time. Before Update everything is working fine, Attached a short movie, how the failure looks. Sorry, file seems to large for appendix. Can I send it to another email? Best Manfred |
Author: | ZeXx86 [ Mon 01. Feb 2021 21:45:21 ] |
Hi, you can upload the file here for example: https://ufile.io/ |
Page 1 of 5 | All times are UTC + 1 hour |
