It is currently Sun 24. Nov 2024 23:31:00
[ 6 posts ] |
Posted: Tue 12. Jan 2021 17:50:12 |
Joined: Wed 21. Dec 2016 15:13:38 Posts: 568 Location: Germany
Hello, I have an simple question, would it be possible to make an intergation menue with reduced content ? There should be only an possibility to change relevant flight parameters - no change of mounting position, no possibillity to change swashplate, pitchrange, receivertype, subtrim etc. -
I think for flying out parameters there could be: - flight style - govenor settings - cyclic ring ? - rudder endpoints ? - cyclic gain - rudder gain and (common) ? - rotationsspeed (cyclic and rudder) - elevator filter - cyclic feed forward - piruette consistency - expert settings ?
(?= worth discussing)
The good thing would be not to change main parameters, so that the heli would not show an unwanted behavior !
The following thought comes to mind: It would be really great if multiple choice could be used to select which parameters could be changed in the integration menu -
What do you think about this idea ?
Many Greetings Matthias
Edit: Changed Title, was not correct written or misleading, 12.0.21_ 18.39 Uhr
Posted: Wed 20. Jan 2021 22:09:06 |
till now no answers ? does no one have an opinion to that ? Is this so absurd to ask ?
Maybe this is here the false register and does not belong to the support category but if I will ask in an other category no one would read this -
As a good customer, I find it sad that even Tomas does not consider it necessary to answer at least one sentence and sorry there is no excuse that there are more relevant priorities - this is not my first time.
BR
Posted: Wed 20. Jan 2021 22:12:35 |
at the moment we have no plan like this, because we have to finish much more important work. Presently we have really a lot of work in each area. So we are working each day at 120% from around march 2020. It is possible it can be realized once we will finish more important things that people are waiting for.
Posted: Wed 20. Jan 2021 22:23:20 |
Hello, thank's for your reply ! Yes its maybe not the relevantest theme - but what are the "more important things that people are waiting for" ? Can you tell something about that ?
That will be great !
BR
Posted: Wed 20. Jan 2021 22:38:08 |
For example support for new protocols, improved integration, improved rescue, online update system, full support for GeoLink in Spirit Aero and much, much more. We have requests years old that are still waiting. So it is very hard to add everything people wish, while improving the current things.
Your request is certainly technically possible. So if people will wish it it can be added with no problem. Actually Android app has support for this.
Posted: Sat 23. Jan 2021 13:43:58 |
Hello, That doesn't sound bad, what is to come - the advantage of making settings with the integration is that nothing has to be plugged in / unplugged and no additional device (pad) has to be used. Connecting and disconnecting cables would not be necessary, because I don't want to have the WIFI module or bluetooth module plugged in all the time -
You could find out whether there is a general need by means of a survey - is that also possible here in the forum?
BR
[ 6 posts ] |
Users browsing this forum: No registered users and 25 guests |
