Spirit System
[SOLVED] Spirit 2 and Jeti DS16
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4471
Author:  nzlsubzero [ Mon 04. Jan 2021 8:45:59 ]
Post subject:  [SOLVED] Spirit 2 and Jeti DS16
Hi
I am trying to get AUX1 working for the throttle. I have assigned the 'Throttle' in the setup to Channel 1. This should have the throttle output now on AUX1 output from the unit. The ESC however will not initialise. If i however use an RX output to the ESC, I can get the ESC to work. I would prefer to use AUX1.
Any suggestions will be very helpful.
Author:  ZeXx86 [ Mon 04. Jan 2021 8:48:44 ]
Post subject:  Re: Spirit 2 and Jeti DS16
it is enough to recalibrate the ESC, because it has throttle range from the receiver.
Or you can change settings in the Spirit unit in the General - Throttle - Throttle Range so it will match the old range from receiver.
Range from receiver is 1000 - 2000us. So after changing everything should work.
Author:  nzlsubzero [ Mon 04. Jan 2021 8:57:25 ]
Hi ZeXx86
:D :lol:
That worked. Excellent.
Thanks for the prompt response. Much appreciated.
Cheers
http://www.phpbb.com/
