It is currently Sun 24. Nov 2024 12:49:28
PostPosted: Fri 01. Jan 2021 12:26:27
Hi there,
My Mac is not recognising my spirit RS, I have the latest spirit settings software and have installed the usb driver too. The RS unit connects with windows fine but not through my Mac? Can you help?
Also how do I update the jeti receiver firmware within the RS unit?
SAm
PostPosted: Fri 01. Jan 2021 15:36:33
what OS version are you using? did you check if the interface is recognised? (you can check it i.e. by starting "Terminal" in your Mac and starting the following command (and post the result here): kextstat | grep silabs
maybe you want to check the solution for some macOS problems at the end of this thread: viewtopic.php?f=20&t=4409
nb: the Rex within RS unit is updated with Spirit firmware update processes... no extra work to be done!
cheers
Michael
PostPosted: Fri 01. Jan 2021 18:14:01
Thank you for replying. this is what I get with the usb unplugged...
sjmacbook@MacBook-Pro ~ % kextstat | grep silabs
Executing: /usr/bin/kmutil showloaded
No variant specified, falling back to release
I will try with the USB plugged in later. Is that normal though as a starting point?
PostPosted: Fri 01. Jan 2021 18:46:42
please check this video:
PostPosted: Sat 02. Jan 2021 9:07:33
yes, try with USB plugged in... check the result. from the result you posted it seems you are on macOS Big Sur? yufasa's video is a great guide through the installation.
did you check this page: https://www.silabs.com/community/interf ... r110x-SWJK and download the newest driver release for big sur already? i've not yet done myself... will try & report in the next days.
Ciao
Michael
cheers
Michael
PostPosted: Sat 02. Jan 2021 9:30:48
hi all,
following the video Tomas put the link too has solved my problem. The driver listed in the spirit manual is too out of date I think.
Thanks all
Sam
PostPosted: Sat 02. Jan 2021 11:03:07
great you got it sorted out!
@Tomas: i've downloaded & installed the new SiLabs vcp 6.0 for Big Sur... even it did work and the new generation driver loaded successfully: Spirit settings did not recognize the new driver ( which is now located within an application in applications folder and has a new name & extension...). did you already successfully test the new driver under Big Sur? (no problem for me in the moment... i am still running Catalina, Big Sur only in a VM to test it)
cheers
Michael
Users browsing this forum: No registered users and 84 guests
