HW ESC - Spirit RS - Throttle not responding correctly https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4465 |
Page 1 of 1 |
Author: | brenchen [ Thu 31. Dec 2020 23:29:38 ] |
Post subject: | HW ESC - Spirit RS - Throttle not responding correctly |
Happy new year all! I'm building my first FBL heli and I couldn't get the throttle endpoints to work - Not sure which part of the drive train is the issue. Basically, I'm using SpiritRS with 60A HW Platinum V4 going to a Jeti DS12 (Spirit Edition). I have set the us-range in the FBL according to the ESC manual, and calibrated the end points with high/low stick positions. It all sounded fine. But when I try the throttle, I am only getting a spin up at just below half stick. I came from a flybar background, do I still need to adjust the endpoints on the transmitter manually to get the throttle curve right? Thanks in advance! Brendan |
Author: | ZeXx86 [ Fri 01. Jan 2021 9:33:14 ] |
Post subject: | Re: HW ESC - Spirit RS - Throttle not responding correctly |
Hello, maybe you have enabled Governor in the Spirit unit. Both Governors cant be enabled. |
